TwinTurbo.NET: Nissan 300ZX forum - ecu water temp sensor? (n/m)
Halo TTZ
on June 11, 2011 at 12:26 PM
OK TT.Net Gurus, could my ECU be going or what?
posted by 91z tt
on June 11, 2011 at 10:27 AM
91z tt
10:27:41 06/11/11
have you checked compression on #4? (n/m)
aliaZ
10:52:33 06/11/11
Re: have you checked compression on #4?
91z tt
11:00:37 06/11/11
130 is getting pretty low.
JMW300ZX
11:17:53 06/11/11
Easy enough to check the ECU for #4 --- wire in a
jzack
11:24:40 06/11/11
Re: Easy enough to check the ECU for #4 --- wire in a
91z tt
11:25:39 06/11/11
Well then at least that means the ECU is probably
jzack
20:38:17 06/11/11
stock fuel rail?
11:44:53 06/11/11
Re: stock fuel rail?
91z tt
11:46:32 06/11/11
91z tt
11:55:08 06/11/11
is your timing belt on correctly? (n/m)
aliaZ
12:06:07 06/11/11
Re: is your timing belt on correctly?
91z tt
12:38:37 06/11/11
I'm asking about your cam timing, not ignition timing (n/m)
aliaZ
12:59:19 06/11/11
Good recommendation but doubtful
OverZealous (CT)
15:14:24 06/11/11
I'm asking based on the compression numbers
aliaZ
07:19:23 06/12/11
ecu water temp sensor? (n/m) -
Halo TTZ
12:26:57 06/11/11
Re: ecu water temp sensor?
91z tt
12:42:05 06/11/11
I had a ECU go bad on just one Cylinder . . .
toykoz32
12:27:54 06/11/11
Re: I had a ECU go bad on just one Cylinder . . .
91z tt
12:43:12 06/11/11
This belongs in the TECH forum
OverZealous (CT)
15:11:40 06/11/11
Re: OK TT.Net Gurus, could my ECU be going or what?
txq45
17:34:28 06/12/11
What means injector circuit is bad?
OverZealous (CT)
20:07:41 06/12/11
good tip
aliaZ
11:22:22 06/13/11
