TwinTurbo.NET: Nissan 300ZX forum - stock fuel rail?
Subject stock fuel rail?
Posted by LJZTT on June 11, 2011 at 11:44 AM
  This message has been viewed 196 times.
In Reply To OK TT.Net Gurus, could my ECU be going or what? posted by 91z tt on June 11, 2011 at 10:27 AM
Message When I was fooling with my motor, I apparently mis-seated one of the rail isolators while torquing down my 300 degree rail and it was partially blocking the opening to the #2 cylinder, causing a good sized boost leak and a cutting-out condition. Different than what you describe, yes, but may be worth checking out if you are running out of ideas. No need to disassemble anything, just boost leak test it and listen for the leak @ the injector
click for photos by SnowmanZ
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery."
--Winston Churchill
END THE FED
....learn why, in 42 minutes
Full Pardon for PFC Bradley Manning
