TwinTurbo.NET: Nissan 300ZX forum - I would stick with the factory recommendation. Remember >>>
Subject I would stick with the factory recommendation. Remember >>>
Posted by ZUL8TR on June 10, 2011 at 10:11 AM
  This message has been viewed 91 times.
In Reply To Yes the bolt is out. I have also counted the belt's teeth posted by treese88 on June 09, 2011 at 11:11 PM
Message that when the engine is running and warming up the belt gets greater tension due to the heat buildup in the belt. Might just do the 4mm setting on the arm and adjust belt tension as recommended in the service manual.
ZUL8TR in Orlando,FL
