TwinTurbo.NET: Nissan 300ZX forum - I have 2 recommendations you can try looking into.
Subject I have 2 recommendations you can try looking into.
Posted by Tony@GZ on June 09, 2011 at 5:35 PM
  This message has been viewed 92 times.
In Reply To Rear Pads/Rotors wearing faster than Fronts '93 TT posted by Mike (Raleigh) on June 09, 2011 at 01:11 PM
Message #1 Ensure your front calipers are on the correct sides. Bleeder nipples need to be on the top. They will never bleed all of the air out of them if they are on the wrong sides.
#2 Inside the Master cylinder there is a dual piston assembly and a proportioning valve. There might be an issue with inside there so you might want to see if you can install a known working one to test to see if your breaking response improves.
