TwinTurbo.NET: Nissan 300ZX forum - Re: IMPORTANT! Need answer within the next 10 minutes.
Subject Re: IMPORTANT! Need answer within the next 10 minutes.
Posted by diamond20601 on June 08, 2011 at 8:06 PM
  This message has been viewed 135 times.
In Reply To IMPORTANT! Need answer within the next 10 minutes. posted by rojoloco (San Diego) on June 08, 2011 at 07:39 PM
Message :Are you getting the busying noise of the injectors priming when you got to turn on the car over because it you are not then you might want to check you fuse that are beside the battery.
I had a customer that car would start sometimes and then not start other time. It would also cut off while driving sometime and after tracing the wire end up find that the wire had a piece of rubber that was missing causing it make contact with the body of the car.
