TwinTurbo.NET: Nissan 300ZX forum - if it won't even crank you have other issues (n/m)
aliaZ
on June 08, 2011 at 7:50 PM
IMPORTANT! Need answer within the next 10 minutes.
posted by rojoloco (San Diego)
on June 08, 2011 at 07:39 PM
19:39:25 06/08/11
if it won't even crank you have other issues (n/m) -
aliaZ
19:50:06 06/08/11
Sounds like the perfect excuse to have your club meeting
MrOzzie5183
19:51:41 06/08/11
Dont risk it.. When you rush is when other things breaks...
Zski
19:52:16 06/08/11
I just checked it with Blazt.
19:57:29 06/08/11
Never put it passed the starter relay to F up
CoHPhasor
20:01:28 06/08/11
Talking to Joe Allison now. He is suggesting the same thing. (n/m)
20:02:58 06/08/11
25230-89981 or starter relay bypass
Gromit
20:10:21 06/08/11
iff this is the issue, AutoZone should have it (n/m)
Gromit
20:27:33 06/08/11
Might be a battery issue....
MrOzzie5183
20:02:49 06/08/11
Batter is at 12.53v. Bought it 2 days ago.
08:42:31 06/09/11
Did you look into the starter relay? Did you try to bypass
Gromit
10:47:26 06/09/11
Haven't had time yet.
15:42:39 06/09/11
It should start but will drive like crap, with the MAF code
Gennosuke
20:03:47 06/08/11
Re: IMPORTANT! Need answer within the next 10 minutes.
diamond20601
20:06:38 06/08/11
Check the rubber grommets on the cluch pedal.
z32z
20:09:51 06/08/11
The switch was the first thing I tried.
20:13:06 06/08/11
Have a similar issue with a Z, need help in tech. (n/m)
ZiNnYc
20:31:22 06/08/11
Check all of the plugs behind the passenger headlight...
Wright (Ca)
21:50:53 06/08/11
I love (woody75's) Z. Very clean and well done Z. (n/m)
z32z
22:43:25 06/08/11
First thing that went through my mind.
Woody75 (Denver)
08:13:02 06/09/11
I looked this morning before I left for work.
15:43:20 06/09/11
I've heard theft can mess with it too, double-unlock the
CoHPhasor
14:08:14 06/10/11
It was the starter relay.
21:33:11 06/11/11
