TwinTurbo.NET: Nissan 300ZX forum - Fusible links are between the battery and those systems...
Subject Fusible links are between the battery and those systems...
Posted by jzack on June 08, 2011 at 10:27 PM
  This message has been viewed 184 times.
In Reply To Z doesnt start, ideas needed, electrical guru please. posted by ZiNnYc on June 08, 2011 at 07:36 PM
Message something to check first, small black box in front of battery. If those are OK I'd then verify all is good with the battery wires including the one going into the fusible links box. Also check the ground lug that's right behind the battery's negative terminal - sometimes that frays over time (at the bend). Lastly if that's all good - perhaps a bad ignition switch? Last thing I'd check but something to consider if the car has a lot of miles...
OK?
