TwinTurbo.NET: Nissan 300ZX forum - 2nd. That's what I've used to get to those clamps.
Subject 2nd. That's what I've used to get to those clamps.
Posted by doug8867 on June 08, 2011 at 8:10 PM
  This message has been viewed 124 times.
In Reply To 1/4" sockets are highly under-rated, and your friend. posted by CoHPhasor on June 08, 2011 at 12:25 PM
Message For the drivers side I had to wedge my hand/wrist down by my clutch master cylinder. You'll find the angle you need eventually, but you likely will end up with some scrapes on the wrist forearm area. :-) You might also need to use a short pivot extension on the ratchet if your clamp is at an odd angle, so that you can position your socket at the right angle. Hope that helps.
