TwinTurbo.NET: Nissan 300ZX forum - Re: Plenum pull question - turbo outlet pipes
Subject Re: Plenum pull question - turbo outlet pipes
Posted by johnbsz on June 08, 2011 at 5:44 AM
  This message has been viewed 135 times.
In Reply To Plenum pull question - turbo outlet pipes posted by RedKev on June 07, 2011 at 09:07 PM
Message I just did mine also. It is a bear. I had a Skill 1/4 drive with a long extension and 10mm socket. The Skill is just a battery powered ratchet drive that turns with the push of a button, something like an air driven ratchet. Anyway, I used the extension under the master brake cylinder so I had access for the drive.
