TwinTurbo.NET: Nissan 300ZX forum - yes its normal to smell a little gas in plenum and-->
Subject yes its normal to smell a little gas in plenum and-->
Posted by Bo (houston) on June 08, 2011 at 12:20 AM
  This message has been viewed 202 times.
In Reply To Coolant level is good. No leaks detected. (n/m) posted by wolftg (DEN) on June 07, 2011 at 11:53 PM
Message see a little oil in there because it gets in there through the pcv valves. You're probably burning oil then if its not coolant. The next easy thing to test is look at your plugs and do a compression test. If thats all good then the oil could be coming from your turbo seals. Are those the original stock turbos with 116k?
