TwinTurbo.NET: Nissan 300ZX forum - and it's normal to smell gas fumes in the plenum? (n/m)
wolftg (DEN)
on June 07, 2011 at 11:46 PM
Check your coolant level and -->
posted by Bo (houston)
on June 07, 2011 at 11:02 PM
Here are the symptoms, advice appreciated!
wolftg (DEN)
18:34:21 06/07/11
forgot to mention that smoke smells of gas seems to be rich (n/m)
wolftg (DEN)
19:35:15 06/07/11
Bo (houston)
23:02:15 06/07/11
and it's normal to smell gas fumes in the plenum? (n/m) -
wolftg (DEN)
23:46:13 06/07/11
Coolant level is good. No leaks detected. (n/m)
wolftg (DEN)
23:53:52 06/07/11
yes its normal to smell a little gas in plenum and-->
Bo (houston)
00:20:43 06/08/11
Your Spark plugs can tell you alot about how your engine is
Bo (houston)
00:32:56 06/08/11
One turbo was replaced at 70k, the other is stock.
wolftg (DEN)
08:50:10 06/08/11
Incorrect on smoke color diagnosis.
CoHPhasor
12:32:50 06/08/11
Thanks yes plugs are good reg/damper is new how do you check
wolftg (DEN)
13:04:48 06/08/11
Fuel pressure gauge and see if it drops off after shut down.
Woody75 (Denver)
14:51:30 06/08/11
