TwinTurbo.NET: Nissan 300ZX forum - Here are the symptoms, advice appreciated!
Subject Here are the symptoms, advice appreciated!
Posted by wolftg (DEN) on June 07, 2011 at 6:34 PM
  This message has been viewed 190 times.
Message 95TT 116k miles
1k rpm at start, after 60 seconds drops to 800 or so
warms, whisps of white smoke from both sides of exhaust (stillen). more smoke with throttle.
new fuel dampener/regulator, new pvc valves, checked for vac leaks. new plugs, tested all injectors (avg. 11.2 to 11.8 ohms)
all clicking, passed power test. O2 sensors check out ok from datascan. Took off balance tube, smells of fresh gas in plenum, glossy wet look inside. Other than this seems to run smooth, boost seems ok +7 at 4k rpm.
Any ideas folks?
Thanks in advance.
My95
