TwinTurbo.NET: Nissan 300ZX forum - ^^correct answer^^ (n/m)
aliaZ
on June 07, 2011 at 5:50 PM
your clutch master cylinder is leaking at the rear seal
posted by Sevore
on June 07, 2011 at 12:47 PM
Need help with brake fluid leaking under the dash
Shorebreak
02:46:54 06/07/11
Mine is leaking down the engine side of the firewall
johnbsz
06:28:52 06/07/11
Thing is that only the clutch reservoir is loosing fluid....
Shorebreak
11:03:38 06/07/11
Re: Thing is that only the clutch reservoir is loosing fluid....
johnbsz
14:18:44 06/07/11
oops...missed that too (n/m)
aliaZ
15:34:33 06/07/11
replace your brake master cylinder (n/m)
aliaZ
06:36:08 06/07/11
^ This is correct. (n/m)
Draker (Eugene, OR)
11:37:10 06/07/11
Sevore
12:47:44 06/07/11
^^correct answer^^ (n/m) -
aliaZ
17:50:31 06/07/11
You could just buy a clutch master cylinder rebuild kit it's
Bo (houston)
23:35:00 06/07/11
