TwinTurbo.NET: Nissan 300ZX forum - Re: Thing is that only the clutch reservoir is loosing fluid....
johnbsz
on June 07, 2011 at 2:18 PM
posted by Shorebreak
on June 07, 2011 at 11:03 AM
Sorry, I jumped right to the master brake cylinder. I missed that you said it was the clutch master that was leaking down. The two reservoirs are not connected and yes, change out the clutch master cylinder.
Need help with brake fluid leaking under the dash
Shorebreak
02:46:54 06/07/11
Mine is leaking down the engine side of the firewall
johnbsz
06:28:52 06/07/11
Shorebreak
11:03:38 06/07/11
Re: Thing is that only the clutch reservoir is loosing fluid.... -
johnbsz
14:18:44 06/07/11
oops...missed that too (n/m)
aliaZ
15:34:33 06/07/11
replace your brake master cylinder (n/m)
aliaZ
06:36:08 06/07/11
^ This is correct. (n/m)
Draker (Eugene, OR)
11:37:10 06/07/11
your clutch master cylinder is leaking at the rear seal
Sevore
12:47:44 06/07/11
^^correct answer^^ (n/m)
aliaZ
17:50:31 06/07/11
You could just buy a clutch master cylinder rebuild kit it's
Bo (houston)
23:35:00 06/07/11
