TwinTurbo.NET: Nissan 300ZX forum - your clutch master cylinder is leaking at the rear seal
Subject your clutch master cylinder is leaking at the rear seal
Posted by Sevore on June 07, 2011 at 12:47 PM
  This message has been viewed 798 times.
In Reply To Need help with brake fluid leaking under the dash posted by Shorebreak on June 07, 2011 at 02:46 AM
Message if your clutch resevoir is loosing fluid and you are noticing the leak inside of the car the rear seal on your clutch master is leaking and the clutch master will need to be replaced. if your are noticing brake fluid leaking inside the engine bay check where the brake master mates with the booster for fluid running down that means the brake master rear seal is leaking.
