TwinTurbo.NET: Nissan 300ZX forum - It is curious that there is no smoke or fouling
Subject It is curious that there is no smoke or fouling
Posted by johnbsz on June 07, 2011 at 6:43 AM
  This message has been viewed 85 times.
In Reply To Im dealing the the exact same thing posted by Michaels90na+1 on June 06, 2011 at 01:17 PM
Message My car is the same, no smoke or fouling on that cylinder. If you check your compression, do it just after shutting down the engine. Pull the fuel pump relay and all plugs before doing the test. I did mine after pulling the plenum and the car had set for 2 weeks is my shop. It is best to do it with the engine warm and oil up in the cylinders. When I get back to it, I will do the same and we can compare numbers.
