TwinTurbo.NET: Nissan 300ZX forum - Re: How many fastener?
Subject Re: How many fastener?
Posted by 90GoldZ on June 06, 2011 at 10:58 PM
  This message has been viewed 117 times.
In Reply To How many fastener? posted by JMartz on June 06, 2011 at 07:38 PM
Message 1. Remove the water pipes(yellow lines).
2. Remove the bolts (B) to the tubes that go around the engine and onto the underside of plenum, then remove the 10mm bolts around where the green dots are placed(they hold the tube onto a bracket). There should be one on each side. Then remove the tube.
3. Cut tube going to driver's side exhaust manifold short as possible.
4. Remove bolts labeled "A" in the picture. You might be able to lean the engine a bit forward or backward for a bit more wiggle room for the bolts to come out. I've had to cut them a few times :(
5. Take EGR off. You might need to turn it a bit for it to be able to come out. After it's out, clean the flanges for the water pipes, add new silicone, and put them back on.
In total it should be 8 bolts.
6-12mm
2-10mm
