TwinTurbo.NET: Nissan 300ZX forum - Re: What to do about a bad #1 injector...
Subject Re: What to do about a bad #1 injector...
Posted by Ted (92TT) on June 06, 2011 at 7:07 PM
  This message has been viewed 122 times.
In Reply To What to do about a bad #1 injector... posted by pa300 on June 06, 2011 at 06:35 PM
Message In answer to your question, a full set of OEM injectors is around $1000, parts only. No reason to replace the full set though, unless you are upgrading. You haven't filled out your profile, so don't know what year or model you have, but early model injectors are prone to very rapid failure from the ethanol additives in modern fuel.
If you have an early model, you should seriously consider upgrading to the newer style injectors. They are not a direct replacement, but there are several conversion options. Search "injector failure" for more info.
Search "dremel method" if you only want to replace the bad one.
