TwinTurbo.NET: Nissan 300ZX forum - Use a stright screwdriver turn all the way clock wise hold
300zx_2+2
on June 06, 2011 at 2:44 PM
Re: Did you check to see if you have any codes?
posted by z32r34
on June 05, 2011 at 03:54 PM
For 3-5sec then turn all the way back counter clock wise. And then the little light and check engine light will flash at you.
-ZNOEVIL-
any idea?
z32r34
10:33:40 06/05/11
Did you check to see if you have any codes? (n/m)
300zx_2+2
12:57:52 06/05/11
z32r34
15:54:26 06/05/11
Use a stright screwdriver turn all the way clock wise hold -
300zx_2+2
14:44:52 06/06/11
did you install OEM 370cc injectors or bigger injectors?
JoshE300zxTT
17:43:18 06/06/11
Re: did you install OEM 370cc injectors or bigger injectors?
jameyguy
23:46:45 06/06/11
