TwinTurbo.NET: Nissan 300ZX forum - sounds like no fuel if you did the CAS trick.
Subject sounds like no fuel if you did the CAS trick.
Posted by 5280Z_nightstalker on June 06, 2011 at 2:58 AM
  This message has been viewed 97 times.
In Reply To Help. No start / No spark posted by sunroof446 on June 05, 2011 at 02:33 PM
Message The CAS procedure where you spin it while its plugged and the ignition is in the ON position determines that injectors are firing. Check the TPS and make sure it is set right. The car is turning over correct? If it is and just not starting then it is possible you have bad injectors which could cause a rough idle or no starting at all.
Since you also say you installed a new harness PLEASE double check that every last plug is plugged in right.
"Do you guys put the key in "balls down", or up?" -BobbyT 10:28:19 03/06/09
tt.net
