TwinTurbo.NET: Nissan 300ZX forum - pinches O-Ring.. Its leaking fuel into your cylinder..
Crim
on June 05, 2011 at 5:42 PM
Help! engine rebuild first start up
posted by gman300zxtt
on June 05, 2011 at 03:36 PM
If you continue to try to start it, it *will* hydro-lock. Fix the problem before continuing.
1990 2+2 TwinTurbo
gman300zxtt
15:36:51 06/05/11
Check and make sure you didn't pinch any injector o-rings.
JMW300ZX
15:53:32 06/05/11
Re: Check and make sure you didn't pinch any injector o-rings.
gman300zxtt
16:00:46 06/05/11
Are you sure you are getting spark?
JMW300ZX
16:06:15 06/05/11
Re: Help! engine rebuild first start up
gman300zxtt
15:55:06 06/05/11
I would agree with JMW... When I replaced a few injectors
JonnyZ(SoCal)
16:08:04 06/05/11
Don't start it! Until you solve the fuel leak. I know
zellamay
16:28:06 06/05/11
pinches O-Ring.. Its leaking fuel into your cylinder.. -
Crim
17:42:33 06/05/11
Hmm? those o-rings I got from NAPA could of definitely
gman300zxtt
21:22:20 06/05/11
Thanks guys! :) I appreciate your opinions and help!
gman300zxtt
21:34:18 06/05/11
Yeah, it already is hydro-locked.
ZTurboFan
00:01:48 06/06/11
Oh, yeah, right, and then all the usuals...
ZTurboFan
00:05:41 06/06/11
The engine didn't even turn over!
gman300zxtt
18:39:49 06/06/11
Probably should replace the oil
Crim
20:57:40 06/06/11
Re: The engine didn't even turn over!
ZTurboFan
01:30:02 06/07/11
I've decided to replace the oil
gman300zxtt
01:40:12 06/08/11
