TwinTurbo.NET: Nissan 300ZX forum - Re: fuel issues
Subject Re: fuel issues
Posted by Bo (houston) on June 05, 2011 at 3:08 PM
  This message has been viewed 96 times.
In Reply To fuel issues posted by ZfreakTT on June 04, 2011 at 10:45 AM
Message check your fuel pump voltage while you're turning the motor over it should be 6 or 7 volts. if its not getting any volts its probably your fuel pump controller which is located behind the drivers seat. If it turns out to be your fuel pump you can get one at autopartswarehouse.com I got mine there and it was the same brand as the autozone one but $100. cheaper.
