TwinTurbo.NET: Nissan 300ZX forum - Re: Worn struts causing bad front camber?
Subject Re: Worn struts causing bad front camber?
Posted by jameyguy on June 05, 2011 at 12:26 PM
  This message has been viewed 242 times.
In Reply To Worn struts causing bad front camber? posted by CoHPhasor on June 03, 2011 at 12:50 PM
Message :
: I have a stock suspension Z and just got new tires yesterday.
:I got stock 245-45-16's, and went from narrow front wheels to TT rears all around.
When the tech did the alignment he noted that the front PS tire had -1.9* camber?
:(The DS was -1.3*)
There is not a way to adjust the camber without A/M setup, right?
:The tech looked for bent pieces and found none. He suspects my struts to be wearing out.
I don't know if/when the P.O. replaced shocks/struts.
: Is he correct? If so, I guess I'll need to look into my options.
:(I can make them re-align it free for only 30 days)
Thanks for the help in advance, as always!
