TwinTurbo.NET: Nissan 300ZX forum - Likely that return system was clogged -- the tank is suppose
Subject Likely that return system was clogged -- the tank is suppose
Posted by jzack on June 04, 2011 at 9:44 PM
  This message has been viewed 113 times.
In Reply To Fuel Vent Line - How does it work? posted by yobobrox on June 02, 2011 at 02:36 PM
Message to pull vapors from the canister back into the tank. Tank creates a vacuum as the fuel is pushed out and into the engine. If return system is clogged - that can't happen.
FYI -- I once had another car where the vapor canister became clogged and every so often the car would stall until I opened the filler cap to relieve the pressure. It was a non fuel injected system, so not as much drama with the tank...
