TwinTurbo.NET: Nissan 300ZX forum - It can leak on either side
Subject It can leak on either side
Posted by Broke_as_**** on June 02, 2011 at 7:57 PM
  This message has been viewed 82 times.
In Reply To Brake fluid leak around master cylinder posted by johnbsz on May 31, 2011 at 10:01 AM
Message Pretty common to see it on the engine bay side. Anyway, replacing the master cylinder or rebuilding it should solve the problem. One thing you might check before buying anything is to make sure it's not a loose connection to one of the lines.
