TwinTurbo.NET: Nissan 300ZX forum - Need help with wierd hestiation issue.
Subject Need help with wierd hestiation issue.
Posted by 91z tt on June 02, 2011 at 7:32 AM
  This message has been viewed 105 times.
Message Hi, I have developed a hesitation issue between 1500 and 1800 rpm's. The hesitation happens within the same range no matter what gear. I have done the following: replaced all injectors, all coil packs, all injector ends - tested same through harness at ECU. Readings were all ~ 12.2 ohms. Ran a Power Balance test with Conzult. I did this SEVERAL times. Each time, a different cyliner is showing up bad. WTF? I ran a compression check, all in spec. Tested the CAS and PTU, good.O2 sensors, good. Cleaned all ground points, and connectors on PTU, CAS temp sensor, and MAF sensors (both N62, both tested good). Any help would be GREATLY appreciated as I'm fresh out of ideas. Thanks!!!
