TwinTurbo.NET: Nissan 300ZX forum - still wont start...
Subject still wont start...
Posted by momo2379 on June 01, 2011 at 3:16 PM
  This message has been viewed 120 times.
Message yes I used the search function, but it wasn't exactly what I was looking for, It did help some, so, any help would be appreciated, so here's my dilema, battery is good, not sure if I checked the starter right, battery cable is getting 12 volts, is there any cable that should be getting 12 volts? the ignition cable? should it also show 12 volts? it is cranking fine, so I know to check if I'm getting fuel and spark, searching led to me the ignition relay behind the driver side fender well, so I jumped pin 3 to pin 5, is that correct? still no starting if that is correct, I printed out the "code 21 write up" which is the TC for no spark condition, however I did the ECU diagnostic and got code 55, no problems detected...I disconnected the outgoing fuelline from the filter, fuel flowed steadily....what else do I need to check??????
