TwinTurbo.NET: Nissan 300ZX forum - Instead of clip pliers, consider a cheap set of 90 degree
Subject Instead of clip pliers, consider a cheap set of 90 degree
Posted by evan_aggie on June 01, 2011 at 1:29 PM
  This message has been viewed 146 times.
In Reply To Hi Alex! The compressor outlet pipe is making contact posted by Barry (NJ) on May 30, 2011 at 08:01 PM
Message nose pliers from HF for $5 or $6, and then if needed (which I did), use a dremel to grind the ends off a bit to make little hooks at the tips. That worked great for me. Otherwise, I kept fussing with various spring-clip pliers that would never hold the large ring-clip really well.
