TwinTurbo.NET: Nissan 300ZX forum - Brake fluid leak around master cylinder
Subject Brake fluid leak around master cylinder
Posted by johnbsz on May 31, 2011 at 10:01 AM
  This message has been viewed 145 times.
Message The leak is going down the engine side of the fire wall and on to the floor. I put fluid in it about every two months. Is the Master cylinder leaking into the booster and then to the floor? I thought the master cylinder if it leaked around the seals would leak into the passenger side of the firewall? I assume the master is bad and needs to be replace.
