TwinTurbo.NET: Nissan 300ZX forum - The Z1 SS Lines are larger and are not retricted. The OEM
Ziceman(East TN)
on May 30, 2011 at 10:03 PM
Why not use the OEM lines that went to the OEM cooler? (n/m)
posted by JMartz
on May 30, 2011 at 09:56 PM
return hose has a restrictor in it that slows the flow.
Z1 Full Flow Oil Cooler Bypass Install.
Ziceman(East TN)
16:57:41 05/30/11
Thnx for the tips :) (n/m)
samsungz
17:09:01 05/30/11
nice ! (n/m)
The Devils Z
17:11:43 05/30/11
Is there provisions for oil temp/pressure sensors?
toykoz32
17:42:17 05/30/11
No, there are no extra ports in the Mocal Oil Sandwich
Ziceman(East TN)
18:08:53 05/30/11
use a different adapter
zgene4
22:02:27 05/30/11
Awesome, Thanks (n/m)
toykoz32
22:32:43 05/30/11
np (n/m)
zgene4
22:23:28 05/31/11
VFAQ (n/m)
Zski
17:47:05 05/30/11
Well done (n/m)
Z32TT-R
18:36:41 05/30/11
Hmmm... I wonder if they can sell me the bolt and block off
JonnyZ(SoCal)
18:40:54 05/30/11
What sandwich plate do you have? (n/m)
toykoz32
19:18:35 05/30/11
looks like a nylon washer was provided instead of a copper
induetime
20:47:24 05/30/11
Yes, it is a nylon washer. Welcome, hope they help. (n/m)
Ziceman(East TN)
20:52:17 05/30/11
I didn't think of it earlier, but one could use the copper
Ziceman(East TN)
21:48:25 05/30/11
FYI... I changed the nylon washer out and used the OEM
Ziceman(East TN)
12:58:00 06/01/11
Move to Tech Forum and VTF! (n/m)
ForceFedTT (SoCal)
21:23:16 05/30/11
Nice! Was looking at this mod last night :) (n/m)
sak01
21:41:28 05/30/11
JMartz
21:56:58 05/30/11
The Z1 SS Lines are larger and are not retricted. The OEM -
Ziceman(East TN)
22:03:02 05/30/11
likely not rated for the pressure of a full flow system (n/m)
aliaZ
05:51:51 05/31/11
Nice write up! Hope to install this kit on my Z soon! (n/m)
Z_Pilot
22:26:08 05/30/11
Did your oil pressure increase at all?...
Zinn2win
01:47:27 05/31/11
the stock gauge is all I have too. I will observe the
Ziceman(East TN)
08:48:46 05/31/11
My pressure results were pretty much in line with what you
Ziceman(East TN)
08:07:01 06/03/11
Joe, thanx for the info
ubermiach
07:39:38 05/31/11
Hey miach, I just have the stock gauge, but I will post
Ziceman(East TN)
08:50:24 05/31/11
After driving the Z I can't say that I noticed a difference
Ziceman(East TN)
08:11:13 06/03/11
Nicely done, but forgot to mention when to tighen the
09:47:47 05/31/11
You are correct. It is left loose until you can clock it
Ziceman(East TN)
11:09:22 05/31/11
Good job. I would not cut those hardlines if at all possible
BoneZ
10:16:11 05/31/11
I would have liked to removed them intact just to have, but
Ziceman(East TN)
11:11:37 05/31/11
Is the oil filter now lower?
JMartz
11:43:22 05/31/11
It's probably an inch lower, but no clearance issues. (n/m)
Ziceman(East TN)
12:11:59 05/31/11
