TwinTurbo.NET: Nissan 300ZX forum - hey man i am fighting the exact same problem!
Subject hey man i am fighting the exact same problem!
Posted by JoshE300zxTT on May 29, 2011 at 9:25 PM
  This message has been viewed 110 times.
In Reply To Safety Boost Issues posted by RVAZ on May 29, 2011 at 01:39 PM
Message except i keep throwing the code 34...knock sensor...thats why i am in safety boost mode....maybe you are running lean at WOT and its causing it to pre-detonate/spark knock...causing the knock sensor to pick it up and drop it into safety boost mode. Because all safety boost mode is for is to drop the boost to a safe level so that way it wont detonate....you can by pass that by relocating your knock sensor...but i don't recommend that especially if you have a knock or pre-detonation!....my knock sensor works at the moment but im still throwing the code...so my next step is to get a wideband and read the a/f ratio and see if im lean at WOT or certain RPM's!
Josh E.
