TwinTurbo.NET: Nissan 300ZX forum - Maximum 186psi, minimum 142psi, Maximum difference between
Sleeper_TTZ(SeKy)
on May 28, 2011 at 12:20 PM
Translation, Z's Smoking bad.....
posted by Sleeper_TTZ(SeKy)
on May 28, 2011 at 12:03 PM
cylinders 14 psi, That the FSM answer. I would say 150psi to 160psi if on a fresh rebuild. The numbers should go up as the rings get worn to fit the block.
I lot smoke from muffler can can somebody give me idea
Negritoz32
10:13:46 05/28/11
You installed new CHRAs? (n/m)
ZiNnYc
11:56:16 05/28/11
Re.
Negritoz32
12:17:26 05/28/11
who rebuilt them (n/m)
ZiNnYc
12:34:25 05/28/11
Re: who rebuilt them
Negritoz32
12:36:28 05/28/11
Sleeper_TTZ(SeKy)
12:03:07 05/28/11
How much compression is too much
Negritoz32
12:12:25 05/28/11
lol. Youre looking for too little of an amount.
ZiNnYc
12:17:16 05/28/11
170 psi (n/m)
Negritoz32
12:20:14 05/28/11
Maximum 186psi, minimum 142psi, Maximum difference between -
Sleeper_TTZ(SeKy)
12:20:23 05/28/11
Re so when rings get worn i go have more psi (n/m)
Negritoz32
12:28:44 05/28/11
Step away from your motor and call Import Parts Pro (n/m)
ZiNnYc
15:15:25 05/28/11
You asked the same question in January...
thumper
13:55:00 05/28/11
Re: You asked the same question in January...
Negritoz32
14:47:40 05/28/11
either F'ed rings or check your PCV valve hoses
JoshE300zxTT
21:37:54 05/29/11
Re: either F'ed rings or check your PCV valve hoses
Negritoz32
04:59:38 06/01/11
