TwinTurbo.NET: Nissan 300ZX forum - Translation, Z's Smoking bad.....
Subject Translation, Z's Smoking bad.....
Posted by Sleeper_TTZ(SeKy) on May 28, 2011 at 12:03 PM
  This message has been viewed 148 times.
In Reply To I lot smoke from muffler can can somebody give me idea posted by Negritoz32 on May 28, 2011 at 10:13 AM
Message My car is smoking a lot from the exhaust, Oil is running out of the down pipe. Blue smoke is coming out of the right side. The engine was freshly rebuilt. The turbos freshly rebuilt. What do you think it is and thanks in advance for the help.
Most likely turbo problems. Some one else is going to have to chime in to confirm this, but either your turbo rebuild sucked or to much oil psi pushed past the seal in the turbo and thus turned into the water fall you call the down pipe.
While your at it go ahead and compression check the motor to see how good that fresh rebuild is doing.
