TwinTurbo.NET: Nissan 300ZX forum - Has anyone modified the aux fan to turn on with the A/C
Subject Has anyone modified the aux fan to turn on with the A/C
Posted by sak01 on May 27, 2011 at 1:47 PM
  This message has been viewed 142 times.
Message I have searched, with no luck... Has anyone modified the auxiliary fan to turn on any time the A/C is switched on? I am trying to avoid disabling it's original temp design functions...just want to modify it when the A/C is on. If so, how did you do it?
I am concerned with the way it was design...the aux fan does not take A/C pressures into consideration. FYI - I am working on a Z (NA) that seems to have condenser air flow issues at idle...the high side climes when the aux fan is off, but looks good when the aux fan is running. It has a new clutch and radiator fan and is clean from debris.
-Angelo
