TwinTurbo.NET: Nissan 300ZX forum - Just a quick thought. Remove the oil filter>
Subject Just a quick thought. Remove the oil filter>
Posted by ZUL8TR on May 26, 2011 at 1:59 PM
  This message has been viewed 110 times.
In Reply To Any suggestions on how to do that? posted by BlackholeZ on May 26, 2011 at 12:02 PM
Message and add a nipple connector to the center oil filter pipe then connect a hose that will take 90psi to be safe. Place a hose in a metal container that can take the pressure and add oil to the container and have the hose located in the oil with the end close to the bottom. Then pressurize the container to first about 30psito start the oil flow then ramp it up to 50psi.
Here is the lube schematic
[ http://300zx-twinturbo.com/cgi-bin/manual.cgi?list=lc&dir=&config=&refresh=&direction=forward&scale=0&cycle=off&slide=4&design=default&total=15 ]
ZUL8TR in Orlando,FL
