TwinTurbo.NET: Nissan 300ZX forum - Compression Test with Plenum removed
Subject Compression Test with Plenum removed
Posted by johnbsz on May 26, 2011 at 6:31 AM
  This message has been viewed 401 times.
Message Any reason I can't check the compression while I have the plenum pulled? I will pull the fuel pump relay first and will have to reconnect the battery ground.
