TwinTurbo.NET: Nissan 300ZX forum - Re: My TTZ makes exhaust makes noise..pls help
Subject Re: My TTZ makes exhaust makes noise..pls help
Posted by UrbanDiplomat on May 24, 2011 at 6:58 PM
  This message has been viewed 93 times.
In Reply To My TTZ makes exhaust makes noise..pls help posted by BlackTwins on May 24, 2011 at 02:50 PM
Message Don't cut your pipe. If you cut it, and the problem is not solved, you'll have a hell of an exhaust leak to accompany your problems.
Check for irregularities in engine vacuum. If the cat is plugged, that will definitely be off. Also, you can check back pressure at the O2 sensors with something like this: [ http://www.amazon.com/Tool-Aid-33600-Exhaust-Pressure/dp/B0002SQW9S ]
Spend more time on diagnostics before cutting anything.
