TwinTurbo.NET: Nissan 300ZX forum - Check your battery cables.
Subject Check your battery cables.
Posted by Draker (Eugene, OR) on May 24, 2011 at 4:28 PM
  This message has been viewed 84 times.
In Reply To 95 NA won't spin over posted by Z28owner on May 24, 2011 at 04:02 PM
Message Check the battery voltage
Check alternator output voltage (Wouldn't prevent from starting but would cause battery to eventually die)
Check starter relay for click when you turn the key. (Good chance this is the issue)
Nutral saftey switch
Clutch switch
Search the forum because this has been asked many times before you.
