TwinTurbo.NET: Nissan 300ZX forum - It's easier with the pin removed, which is easy
Subject It's easier with the pin removed, which is easy
Posted by Broke_as_**** on May 23, 2011 at 3:38 PM
  This message has been viewed 132 times.
In Reply To Less than an hour trying to find the right combinations. posted by HillZTT on May 23, 2011 at 03:23 PM
Message And then you can push it out of the way or with much juggling you can remove it. Putting the bolts back in the bracket was kind of a pain because you had to reattach the actuator first (or maybe that was just with the Forge actuators) but either way, quite a bit easier than removing the turbo.
