TwinTurbo.NET: Nissan 300ZX forum - Re: vacuum leak
Re: vacuum leak
stiz32
on May 22, 2011 at 7:20 PM
vacuum leak
posted by CGDriven
on May 22, 2011 at 06:32 PM
:Did u make sure to tighten up the egr tubes under the plenum?
The egr is deleted.
NA Idle problem
stiz32
15:45:04 05/22/11
Idle with these cars is very picky. I would start with items
robzone0911
18:32:13 05/22/11
vacuum leak
CGDriven
18:32:41 05/22/11
Re: vacuum leak -
stiz32
19:20:45 05/22/11
Did you replace the lower injector insulators? (n/m)
Draker (Eugene, OR)
20:49:53 05/22/11
Re: Did you replace the lower injector insulators?
stiz32
09:46:09 05/23/11
Normally I would point to the IACV/AAC
Draker (Eugene, OR)
12:02:37 05/23/11
Re: Normally I would point to the IACV/AAC
stiz32
12:49:24 05/23/11
I have an NA and can tell you that
Trailboss
09:39:37 05/24/11
Re: I have an NA and can tell you that
stiz32
10:09:55 05/24/11
