TwinTurbo.NET: Nissan 300ZX forum - they should be stamped, Grade on one side and cylinder
Subject they should be stamped, Grade on one side and cylinder
Posted by Hoppy2 on May 22, 2011 at 8:52 AM
  This message has been viewed 89 times.
In Reply To I forgot I have the online version! posted by Coldfusown on May 22, 2011 at 02:55 AM
Message on the other, Make sure they go on the right rod in the right cylinder and go in correctly. I had all the grades stamped facing the pass side of the block, towards filter tree and cylinder #'s on the other side. I can only see an issue on the lower cylinder numbers if the bearing grade matches the cylinder #..
But I am no pro, Just finished my rod bearings myself.
2 Z's in the making!!
