TwinTurbo.NET: Nissan 300ZX forum - It looks like perforated metal holding in place a pleated
Subject It looks like perforated metal holding in place a pleated
Posted by not4resaleZ on May 21, 2011 at 3:15 PM
  This message has been viewed 83 times.
In Reply To Power steering resevoir question... posted by Serg300zx on May 18, 2011 at 08:29 PM
Message paper type filter media. Just like most motor oil filters but without any kind of bypass.
If not using stock I would install some kind of filter. You could use the stock reservoir and flare the inlet tubes for AN fittings. I'd use the existing hard lines and flare them for A/N fittings anyway and use flex only where required for movement like the existing system. The hard lines will help let the fluid cool better than flex.
