TwinTurbo.NET: Nissan 300ZX forum - 1) Post in technical.
ZiNnYc
on May 18, 2011 at 10:48 PM
pls help, my turboZ loose power when step on gas. why ?
posted by BlackTwins
on May 18, 2011 at 06:51 PM
2) You did a balance test, and isolated the issue to one of your cylinders. Grab a multimeter and check the resistance of that injector (NOT the coilpack). Most likely the injector is dead or on its way out.
3) Try harder with the grammar
BlackTwins
18:51:35 05/18/11
Unplugging the injector connectors w/engine running
Under_Powered
19:03:53 05/18/11
Re: Unplugging the injector connectors w/engine running
BlackTwins
19:55:53 05/18/11
I would start by unplugging and checking every connection
MrOzzie5183
19:05:41 05/18/11
Re: I would start by unplugging and checking every connection (n/m)
BlackTwins
20:24:47 05/18/11
BlackTwins
20:26:53 05/18/11
I can't even read that... too painful. (n/m)
Multi_Read (MO)
19:20:51 05/18/11
Re: I can't even read that... too painful.
BlackTwins
20:18:03 05/18/11
Re: pls help, my turboZ loose power when step on gas. why ? (n/m)
BlackTwins
19:47:37 05/18/11
1) Post in technical. -
ZiNnYc
22:48:03 05/18/11
