TwinTurbo.NET: Nissan 300ZX forum - Re: Re: frustrated w/ electrical problem :(
Subject Re: Re: frustrated w/ electrical problem :(
Posted by momo2379 on May 18, 2011 at 12:44 AM
  This message has been viewed 68 times.
In Reply To Re: frustrated w/ electrical problem :( posted by ba11erz on May 16, 2011 at 04:32 PM
Message :Start with the obvious. (listen and pay attention to dash errors)
:Then isolate.
:All an engine needs to start is spark, fuel, and air...in that order.
:Is there any way you can verify you have adequate voltage going to/from the alt and the starter?
:Can you verify you have fuel going from the pump to the rail?
:Check connections at both the PTU (power transistor unit) and CAS (Crank Angle Sensor) make sure they're plugged in and no visual signs of plug damage.
:An electrical problem can be a once source culprit or a myriad of inoperable devices including connections.
:I hope you have patients because unfortunately that's the only thing that will help you find your prob (aside from the obvious if you are using special testing instruments)
:Borrow someone’s ConZult if you can and if all else fails, pop the clutch in 2nd and see if it stays running.
:Report back and let us know how you fixed it. >good luck
appreciate the info.....I was gonna pull the main engine harness, but then I did a search here and they say you have to pull the engine out!?! Damn!!
also, I see from searches I did, people mention trouble codes...but IIRC the ealy Zs arent OBD2, I know the ecu has a diagnotics button? like a self test? is that where you get the codes from?? if I do the test button, how will I see a fault?? sorry Im a newb, think I can borrow the conzult from NIssan?
