TwinTurbo.NET: Nissan 300ZX forum - See if you can hear the fuel pump spin
Subject See if you can hear the fuel pump spin
Posted by Draker (Eugene, OR) on May 17, 2011 at 11:20 PM
  This message has been viewed 74 times.
In Reply To starting issues.....PLEASE HELP!!!!!! posted by ZfreakTT on May 17, 2011 at 08:15 PM
Message Turn the key and listen by the rear tire. You should hear it buzz in the tank. If you don't, then it's likely it is seized up. Another test you can do is pull the hose at the fuel filter and direct it into a container. Then turn the key, if it pumps out then you've got fuel to the injectors as long as the fuel filter isn't plugged up.
