TwinTurbo.NET: Nissan 300ZX forum - Usually those systems are separate from eachother
Subject Usually those systems are separate from eachother
Posted by BOOZTD 3 on May 17, 2011 at 4:48 PM
  This message has been viewed 139 times.
In Reply To That is very understood, and it's headed to the shop posted by BannonZ on May 17, 2011 at 03:55 PM
Message There are tons of coolant lines on these engines (and if yours is stock, a bunch lie underneath the plenum)
Research the plenum pull/bypass procedure, and that could give you some ideas on where to be looking for the coolant leak. The sweet smell you're getting is most likely the coolant leaking onto the engine somewhere and it burning
