TwinTurbo.NET: Nissan 300ZX forum - did you try squirting a little oil into the cylinder...
Subject did you try squirting a little oil into the cylinder...
Posted by CGDriven on May 16, 2011 at 7:10 PM
  This message has been viewed 107 times.
In Reply To SOLVED: Its compression (or lack of) posted by BOOZTD 3 on May 16, 2011 at 06:39 PM
Message and checking again to see if the compression jumps up significantly? Could help you narrow it down to bad rings or a leaky valve/head.
