TwinTurbo.NET: Nissan 300ZX forum - Re: a tt flex plate has a NA flywheel diameter
Subject Re: a tt flex plate has a NA flywheel diameter
Posted by Cobra swe on May 15, 2011 at 11:52 PM
  This message has been viewed 267 times.
In Reply To a tt flex plate has a NA flywheel diameter posted by Dane (Houston) on May 15, 2011 at 05:04 PM
Message :and all flex plate in automatics nissan, have a NA flywheel diameter (240sx, 300zx, j30, q45)
:NA 240mm
:TT 250mm
Ok, but are you sure on the numbers?
Got 317mm from 2 different sources on the TT flexplate, and my flywheel was 321mm...
So machine the starter surface a couple of mm would do the trick :-) Fingers crossed...
