TwinTurbo.NET: Nissan 300ZX forum - What happens when you put it in gear...
Subject What happens when you put it in gear...
Posted by BOOZTD 3 on May 15, 2011 at 11:30 PM
  This message has been viewed 95 times.
In Reply To Clutch Engagement Problem. Won't go into gear... posted by atomatiX on May 15, 2011 at 10:55 PM
Message and try to start it with the clutch depressed?
If the car lurches forward (dont be parked in front of anything) then you know you're not getting enough disengagement of the clutch from the flywheel. If that happens then you know you're not getting enough travel, which is likely the clutch not being bled enough, or as stated a pivotball issue
