TwinTurbo.NET: Nissan 300ZX forum - Clutch Engagement Problem. Won't go into gear...
Subject Clutch Engagement Problem. Won't go into gear...
Posted by atomatiX on May 15, 2011 at 10:55 PM
  This message has been viewed 193 times.
Message I press the clutch, but it won't go into gear.
What I've done:
1.Bought a one-piece clutch line from z1, so eliminated the other bleed point.
2.New Clutch slave, master, and booster(yup I spent $400)
3. bled the system multiple times
The clutch fork moves when the clutch is depressed, and there is pressure in the pedal(pressure is reduced with the engine running, but should be because of the booster)
I'm suspecting mechanical failure in the transmission/clutch... but I'm not educated in that area. Please help :(
